05 GMC with EDGE and Bully DOG...HELP PLEASE!!!!!!
Discussion in 'General Tow Rig Discussion' started by sledneck100, Oct 24, 2005.
  1. sledneck100
    sledneck100 New Member
    Can anyone help me with this combonation. I have the edge with attitude and the bully dog power pup downloader with a stage 1 shift kit, air intake,and exhaust. I can only run the power pup on level 3 with edge on 0 or the power pup on 2 with edge on 3. The tranny keeps going into limp mode......Is this comman?
  2. 4054x4
    i really have no solid answer... but i would guess that the two different software programs are conflicting with eachother or with the transmission software. or maybe there's just too much power which is making the transmission freak out :confused:... have you modified your transmission at all?
  3. Brisk
    Brisk Well-Known Member
    Castle Rock, CO
    Its hit or miss with the Allison...There are a couple of guys over on thedieselplace.com who are running the Edge on 5/5 and 90-120hp predetors stacked with out limping the trans. Others have similar situations to yours where just a 5/5 Edge will limp it. Look into an upgraded valve body and Torque converter to fix the problem for good waytogo
  4. BadDog
    Running a stack with a stock Alli is asking for trouble. The Edge by itself is capable of putting in +90, maybe +120 tops (with no stalled launches or OD roll ins) without limping. Stacking is only for built trans even on the Alli. Even then, you can do serious damage to the motor if you don't know what your doing when stacking. You may have already done permanent damage to the tranny...
    Edit: Just realized you said you had a "stage 1 shift kit", missed that before. What type? Did you replace the converter? If not, then it's slipping the clutch and causing the limp. To do what your doing, even on the lower settings, you will need at least a Trans-go WITH a good single or tripple disk converter.
  5. RJF's Red Cummins
    I don't understand this. Why would you want to have an Edge turned on 5, then stack another 50-100+ HP on top that? Is this for racing or are you actually driving around like that? I would think the smoke would be rediculously thick and would put uneeded strain on the engine, just for driving around. :doah:
  6. 4054x4
    haha ya seriously... i drive around w/ mine in level 1 or 2 and im still impressed w/ the power compared to what i used to drive (Brent knows haha)
  7. Brisk
    Castle Rock, CO
    rotfl rotfl rotfl I dont know Ben...that little Bronco II sure had some poop! Especially with the 2.9 V6 baby!! rotfl rotfl rotfl But that 4-cyl Auto S-10 sure took the cake when it came to 1/4mile times waytogo
  8. sledneck100
    Thanks for the advice....if i build my tranny up will it stop going into limp mode? Any company you would suggest? OR not suggest. Dont get me wrong the truck goes a lot better with the power pup on three but i want everything i can get.
  9. BadDog
    For up to +150 on a single box (depending on the box) like Edge Hot Juice, a good single disk converter and trans-go kit will hold up to normal "playing around" and semi-hard use according for to most reports.
    For stacking and more exteme use, frequent drag racing, and such like, your probably best going with ATS or SunCoast. Which is better value is a matter of some debate. Do research and then call them for advice on which level you need.
