Anyone know what lubes go in the 07 4x4 manual trans and transfer case ? ATF ? Gear Lube ?? front and rear axle lube suggestions?? Want to switch over to synthetics..used Royal Purple in the past with good results..open to all sugestions..
Well, I am kinda biased towards Amsoil. I use and abuse it and it just holds up. Had nothing but great luck with it. As for lubes, here ya go - Manual Transmission, G56..........12.0 pints - ATF Differential, 9.25 AA Front..........4.6 pints - 75W90 or 75W110 Differential, 9.25 AA EL Front..........4.2 pints - 75W90 or 75W110 Differential, 10.5 AA Rear..........5.3 pints - 75W90 or 75W110 Differential, 10.5 AA EL Rear..........5.3 pints - 75W90 or 75W110 Differential, 11.5 AA Open Rear..........8.9 pints - 75W90 or 75W110 Differential, 11.5 AA Trac-Rite Rear..........8.4 pints - 75W90 or 75W110 Transfer Case,NV271..........4.0 pints - ATF For more info on lubes and capacities, check out the Amsoil Application Guide. Let me know if I can help!
I don't think my 07 has a G56 in it,,,isn't the G56 a cast iron case ? EDIT: DOH !! my bad,,, http://www.dieseltruckresource.com/dev/archive/index.php/t-93225.html
