Under the hood there is a little sticker that says to grease the front drive shaft every oil change. Problem is,, there are no zerk fittings anywhere on the shaft. none on the u-joints and none on the slip shaft splines. It has a double cardan joint at the transfer case and a single joint at the front pinion. No fittings. Same thing with the outer tie rod ends,,,says to grease them in the manual,,but no fittings. any suggestions/feedback ????
im not a dodge owner, but that sounds like a dealer question. if is like the new fords, there are no grease fittings at all. which i do not like.imp:
