ive been burnin oil in my truck an i talk to a guy at the ford shop he said it could be injectors or a turbo problem does any one know how to tell if it is a injector problem or a turbo problem, if it is a injector problem is it hard to pull the injectors out an replace the o rings on them an where can i get them for cheap !
Parts store time, number one you need an injector tester to check it with and then you need the easy to replace o rings just keep em clean and lubed.
