95 Dodge 3500 Dually
Discussion in 'Tow Rigs and Trailers for Sale' started by RFR2212, Oct 4, 2007.
  1. RFR2212
    RFR2212 New Member
    1995 Dodge 3500 Dually
    5.9 Cummins 209k
    5sp manual
    Well maintained driveline
    The Good:
    Recently installed SBC Con FE Clutch-Huckstorf Diesel
    Torque Plate, 60hp injectors, lift pump, and 200k tune up-Scheid Diesel
    New front brakes
    New Rear wheel cylinders
    4 Newer tires
    Newer 4in MBRP exhaust
    Auto Meter EGT/Boost Gauges
    Recently rebuild drivers seat and headliner
    4 Caddy horns
    Comes with cap and home made tool box
    The bad:
    Paint-Vehicle was egged before it bought it, so there are quite a few spots that are primer. Some rust on the doors and passengerside rear cab. It can be seen bleeding through herculiner.
    No stock horn
    No Cruise control
    Leaking cab. Possibly a bad winsheild seal as I've tried alot of the other leaky cab fixes
    Howl from 3rd gear under load. Unk what the problem is, only noticed after the new clutch was installed.
    2 ball joints needed for the front end, though I'll probably take care of this shortly.
    This truck certainly is far from show, but a great working truck. It hauls my bronco with ease and I get about 17-21mpg on the road and 15-17mpg in town. Time for me to move onto a newer nicer truck. Can get other pictures if needed.
    Chicago,IL area
    $8,000.00 obo
    contact me at broncoguy1973@yahoo.com
