Another "Worth It" Thread
Discussion in 'Trailers' started by BurbLover, Jul 26, 2005.
  1. BurbLover
    BurbLover Well-Known Member
    SW Missouri
    Okay, I've got a line on a trailer with the following info:
    Specs:
    - About 12 years old. Hasn't been registered since 01.
    - Had new rear axle just prior to being taken off road.
    - 10K equipment trailer. Was used to haul Skid-Steer.
    - Dual 7K axles w/ brakes.
    - Width is 78".
    - Lenght approx 18'
    - Flatbed bumper pull w/ dual ramps.
    - Comes w/ Spare.
    - PO will have company mechanic go through axles/brakes to ensure working.
    - PO will have mechanic ensure all light working via 7-way plug.
    Needs:
    - Needs 2 tires
    - Doesn't have battery break-away.
    - Deck might last 1-2 years. Pretty bad wood.
    Knowing the above info, is it worth $500?
    Also, with the 78", is this wide enough to haul my 90 K5 w/ 1-ton axles & 38's? This is what would be on it almost all the time.
    COMMENTS/SUGGESTIONS? Thanks.
  2. Burt4x4
    Burt4x4 Well-Known Member
    Modesto, CA
    No, it is not wide enough. Atleaset my 72K5 would be hangin off both sides. I have a 83" deck and I squeeesee thru the fenders just barley.
    I would keep looking for a 83" deck...
    .02c
    Burt
  3. mbryson
    mbryson Well-Known Member
    Salt Lake, UT (OK, just north of there)
    I'd be pretty interested in it if you know anyone coming to UT.....(UROC or something?)
  4. MTMike
    MTMike Well-Known Member
    Billings, Montana
    When my fenders were stationary and 83" apart, I still had to run over them with my K10 on 38" Tires. I built removable fenders and it now fits between the tires without any trouble.
  5. kennyw
    kennyw Member
    Stevens Pass
    My trailer is 75" wide. I can fit a 1 ton K5 with 38" boggers or my stock K5 with 31" AT's just about the same. Either way I end up driving over the fenders. It is fine with a rig in good shape, but when the motor doesnt run or the steering box is ripped off the frame... It can be a lot of work to load/unload.
