BD Power X-Power Sale
Discussion in 'Supporting Vendors' started by Dave@BD-Power, Aug 18, 2006.
  1. Dave@BD-Power
    Abbotsfordf BC
    BD-Power Diesel Performance
    X-Power with X-Monitor​
    To show our appreciation to the members and staff of the TowRig Forum, BD-Power Diesel Performance is offering a special forum price on all Dodge X-Power, X-Power Plus and X-Power - X-Monitors combination kits. This limited time offer is exclusive to members of the TowRig Forum only. If you are not registered and would like to participate in this special offer, simply register and participate in the forums to qualify for the discount.
    The BD X-Power Plus will boost horsepower and torque by controlling Injection Duration and Timing. The X-Power Plus is great for those of you who want all the power with out the hassle of having to stack a tuner with a performance chip. The X-Power Plus can be stacked with most tuners but may cause issues associated with too much timing. This is common when stacking tuners with a performance chip that already have high levels of advanced timing. The X-Power Plus uses a dial to fine tune HP anywhere from 0-170 RWHP for optimal power and controllable EGT’s.
    The BD X-Power will boost horsepower and torque by controlling Injection Duration only. This works great for those of you who are already using a tuner with high levels of advanced timing and are looking for more power through stacking. This eliminates the issues associated with running to much timing. The X-Tuner uses a dial to fine tune HP anywhere from 0-130 RWHP for optimal power and controllable EGT’s
    The BD X-Monitor is our digital gauge package that can be mounted on the Pillar or dashboard. It is available in two or three gauge readouts, and will display EGT’s, boost with an optional third readout for transmission temperature, oil temperature, back pressure or fuel pressure. The X-Monitor will record maximum values and has an alarm mode that can be set for all three display to indicate when you are approaching a pre set temperature or pressure.
    X-Power Plus 2003-04 $649.00
    Special $554.90
    X-Power Plus 2004.5-05 $649.00
    Special $554.90
    X-Power Plus 2003-04 w/ X-Monitor - Pyro & Boost $999.00
    Special $854.10
    X-Power Plus 2003-04 w/ X-Monitor - Pyro, Boost & Trans $1019.00
    Special $871.25
    X-PowerPlus 2004.5-05 w/ X-Monitor - Pyro & Boost $999.00
    Special $854.10
    X-PowerPlus 2004.5-05 w/ X-Monitor - Pyro, Boost & Trans $1019.00
    Special $871.25
    X-Power 2003-04 $579.00
    Special $495.00
    X-Power 2004.5-05 $579.00
    Special $495.00
    X-Power 2003-04 w/ X-Monitor - Pyro & Boost $929.00
    Special $794.30
    X-Power 2003-04 w/ X-Monitor - Pyro, Boost & Trans $949.00
    Special $811.40
    X-Power 2004.5-05 w/ X-Monitor - Pyro & Boost $929.00
    Special $794.30
    X-Power 2004.5-05 w/ X-Monitor - Pyro, Boost & Trans $949.00
    Special $811.40
    *All prices are in USD, Canadian pricing available upon request
  2. Dave@BD-Power
    Abbotsfordf BC
    Christmas Special 25% off all X-Powers
    To show our appreciation to the members and staff of the Cummins Forum, BD-Power Diesel Performance is offering a special forum price on all Dodge X-Power, X-Power Plus and X-Power - X-Monitors combination kits. This limited time offer is exclusive to members of the Cummins Forum only. If you are not registered and would like to participate in this special offer, simply register and participate in the forums to qualify for the discount.
    X-Power Plus 2003-04 $649.00 less 25%
    X-Power Plus 2004.5-05 $649.00 less 25%
    X-Power Plus 2003-04 w/ X-Monitor - Pyro & Boost $999.00 less 25%
    X-Power Plus 2003-04 w/ X-Monitor - Pyro, Boost & Trans $1019.00 less 25%
    X-PowerPlus 2004.5-05 w/ X-Monitor - Pyro & Boost $999.00 less 25%
    X-PowerPlus 2004.5-05 w/ X-Monitor - Pyro, Boost & Trans $1019.00 less 25%
    X-Power 2003-04 $579.00 less 25%
    X-Power 2004.5-05 $579.00 less 25%
    X-Power 2003-04 w/ X-Monitor - Pyro & Boost $929.00 less 25%
    X-Power 2003-04 w/ X-Monitor - Pyro, Boost & Trans $949.00 less 25%
    X-Power 2004.5-05 w/ X-Monitor - Pyro & Boost $929.00 less 25%
    X-Power 2004.5-05 w/ X-Monitor - Pyro, Boost & Trans $949.00 less 25%
