Boost elbow
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by TXDODGE, Sep 16, 2007.
  1. TXDODGE
    TXDODGE Active Member
    Monaville, Tx.
    What is the best adjustable boost elbow or wastegate actuator for my 03.
  2. Hawg Hunter
    Hawg Hunter Active Member
    Central PA
  3. TXDODGE
    Monaville, Tx.
    Thanks. I bought one. It's at home waiting for me. I will install it tomorrow and see if I can get the boost up to about 36-38 psi. With the stock setup I was only seeing about 24.
  4. Hawg Hunter
    Central PA
    Becareful with that boost. Your stock turbo will only stand and only be efficient to 35lbs. IMO, 32lbs is where I would hold the line. A blown turbo can create a real mess.
    Good Luck.
