DOT #'s
Discussion in 'General Tow Rig Discussion' started by Justice, Oct 26, 2006.
  1. Justice
    Justice Well-Known Member
    How many of the haulers in here are register over 10k GVWR? I know any 1-ton dually should be but I'm told that most arn't True or not?
  2. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    I'm not registered on the truth of it I think it only matters if your hauling commerically
  3. Justice
    You are right it is only if you are hauling comericialy, which i am. I had just been running not worrying about it but to run off some of the load boards you need #'s.
  4. rocknbronco
    Flat Top Mtn,Tn
    thats not good
  5. Justice
    thats why i thought id go ahead and get legal
  6. rocknbronco
    Flat Top Mtn,Tn
    yeah it would be much better to get legal that way you can get more jobs by being listed
  7. Trinitytrucking
    Trinitytrucking Member
    long island , NY
    im legal and im heavy too im regestered at 35k
  8. sweetk30
    sweetk30 Well-Known Member
    horseheads, ny,i live in the rust belt.
    i do inspections in my state. and most of the bissness trucks and stuff are under weight registred. some are not even over to the point that when the driver and a small amount of tools is in the truck thay are over weight. :doah:
    so my truck is set at a good middle ground and my trailers are at 9,995lbs. 5 under to save big money on tags every year.
    and in my state unless you are haulin comercial and or have your truck/trailer all stickered up thay dont realy mess with ya in my area at least.
