GM Tests Process to Raise Fuel Economy
Discussion in 'General Tow Rig Discussion' started by RodZZilla, Sep 5, 2007.
  1. RodZZilla
    RodZZilla Well-Known Member
    General Motors Corp. said it is testing a combustion process in concept cars that could raise fuel economy by 15% over current conventional engines, the Associated Press reported.
    The process GM and other automakers are testing, called homogeneous charge compression ignition, approaches the fuel efficiency of a diesel engine without the need for advanced pollution controls, GM said in a statement.
  2. Woods
    Woods Well-Known Member
    Sounds interesting, got a link?
  3. RodZZilla
    That was all they listed in the article. I will see what I can turn up.
