Injector problems
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by strai8up, Mar 7, 2007.
  1. strai8up
    strai8up Well-Known Member
    Middle Georgia
    anyone had any trouble with injectors ? Just started sticking when I crank it up then goes away . not logging a code yet.
  2. Diesel Nut
    Could you be more specific? What is sticking? Injectors can have issues, but I really can't tell you anything from what you are posting. Give me a little more info if you can.
  3. whiterocket5.9
    central illinois
    i havent had any problems that i know of yet.
  4. strai8up
    Middle Georgia
    truck is skipping like injector is stuck open. It is hard to start at first then smokes for a few seconds. Both times it did it. I shut the truck off, re-cranked it and it ran perfect. I figure it is an injector problem because of the skipping when it starts running. I also think that because when it does it , it is like tring to start it up with out fuel it the filter. It does not do it every time or just in the a.m. It is sort of speratic.
