Kaufman trailer "Maximum" car hauler 10k GVWR, brakes on both axles Breakaway Kit Treated deck 6" Channel frame 3" crossmembers on 16" centers 16" 6 lug wheels 2' dovetail 4 D-rings Stake pockets and rub rail Flush mounted lights Diamond plate fenders 10k drop leg jack 2 5/16" Bulldog hitch 83" wide 18' deck length including dovetail
Sweet, sounds familiar! waytogo The one thing I'd change is that I'd add more D-rings if I were to do it again. I have 4, one at each corner and they're mounted on the sides at the front and back. I'd want like 2 more on each side a couple feet from each end for more options to tie the truck down, and also 2 on the front and 2 on the back. So, 12 D-rings total. Overkill I'm sure, but it would have been easier than adding them later. Also, they put my spare mount back a bit farther than I wanted it, it's borderline on interfering with the truck when it's loaded. I asked them to put it as far forward on the deck as possible but I guess it got forgotten in the shuffle. Since you got the 18 foot one it probably would interfere on your trailer if it's put the same distance from the front as it is on mine. One last thing, Kaufman puts a 6 pin industrial connection on the trailers, but will put the 7 pin one on that new trucks have for no charge if you ask for it.
