shift inprver kit for the 48RE
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by Full Pull, Mar 17, 2007.
  1. Full Pull
    Full Pull Well-Known Member
    Lakeland FL
    Has any seen the add in the Diesel Power mag. I called the guy and they said it was around $ 100.00 I am going to get it and maby a larger Pan. anyone already using It ?
  2. Diesel Nut
    Not sure which kit it is, but let me tell you, they are a little more involved to change than the Valve Body. You will get better performance out of a built Valve Body that just the shift kit. There is much more done to performance VBs than just the shift kit. Its a little more money, but much better performance.
    The deep pan is an excellent idea. It will add to the ATF capacity, help cool the ATF, and with a drain plug built in, makes servicing much easier.
  3. Full Pull
    Lakeland FL
    Thanks Dsl Nut I am going to get a Valve body and a Bilit Converter soon.
  4. Diesel Nut
    Right on. What brand are you thinkin about?
  5. Full Pull
    Lakeland FL
    Probly Suncoast. was going to get an Ats but heard they hade a lot of problems.
  6. Diesel Nut
    I do alot of business with Suncoast. I tend to stay away from ATS for most things.
  7. Full Pull
    Lakeland FL
    I saw that Tranny on your site does that come with a converter?
  8. Diesel Nut
    Which one? The Suncoast ones require you to chose the converter. I also have a few other transmission options.
  9. Full Pull
    Lakeland FL
    The 48RE direct replacement one or maby it was the Rebilt factory one.
  10. Diesel Nut
    No factory one here!rotfl
    The basic rebuild from suncoast is listed, and requires a converter. The Nadp is listed with a converter.
  11. PolisHammer
    PolisHammer Member
    One thing about VB and shift kit is $$$ - VB around $400 and shift kit $80.
    If $$ is no object then VB is better than shift kit as additional improvements are done to it
  12. Diesel Nut
    Most average Joe's don't really want to mess with all teh tiny little peices, check balls and springs involved with tearing apart a VB and trying to rebuild it. Shift kits weren't intended for the end user to install, but rather for professional shops to use as a means of upgrading a rebuild. Believe me, spend the money, get the VB.
  13. Full Pull
    Lakeland FL
    Thats what iam probly going to end up doing a converter and VB and a deeper pan.
  14. Full Pull
    Lakeland FL
    I backed up off the power a little till I get some more work done Its too Dangerous Ill end up popin something. Plus babby # 2 is due in june so got to get ready for Him .
  15. Diesel Nut
    Congrats on the up and coming arrival!
