Smarty programmer
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by worken teryx, Jun 26, 2008.
  1. worken teryx
    worken teryx Member
    texas
    How much tq does the smarty put out? And how much beefing up would you have to do to run it on high?
  2. Diesel Nut
    Wow, where to start. Well, in a nut shell if you want to run the highest program with TNT R, you will need
    Built trans or dual disc clutch
    Big single or twins (I recommend twins for driveablity)
    Head studs
    Valve springs
    Fass system
    Now, lets talk a little more about what you want the smarty to do for you. The highest level doesn't always yield the best performance on all trucks. Give me a call, lets talk about it. I bet there is some middle ground here.
