Transmission Conversion Question??
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by LOUDandPROUD, May 3, 2006.
  1. LOUDandPROUD
    Kodiak, Ak
    :confused: Howdy friends, I got ahold of an NV5600 out of a 2005 today. I plan on putting it in my 2002. Does anyone know right off the top of their head if my current transfer case; NP241, will bolt up directly to the 6spd or do I need to change an input or output shaft somehwhere? My current transmission is the 47RE...Should be a fun project! I know that i'll need to lengthen and shorten drivelines and adjust a crossmember but any other advise is apprieciated!
    What you need to find out is the spline count of both transmission's shafts. As far as the shaft length, usually the adapter makes up the difference.
